installation problem
charliewill
I try to install windows vista ultimate on my HP KW303EA but i have problem...
i boot up from the cd , it loads the windows install files... after that i see the blue bar running for about 6 seconds and i see
the windows vista install background... i noticed that my hard drive activity led is always on(red) but the install will not go
on.. it is just stuck at the start i can even get to the windows with the product key...
Please help...
Are you doing a clean install? Do you have the latest BIOS rev on the laptop?
    16GB DDR667
    SAS RAID
How much memory are you using.
Is it on a ide/sata drive or a raid array?
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
