Hello Guy's and Gal's,
I have installed the miracle C compiler on my laptop for my Programming concepts class and I am having trouble. I am running Vista Ult 64x and the instructions I recieved are as follows:
However, when I attempt the first step I receive a "input is not recognized as an internal or external command.
Can you tell me what I am doing wrong or if there is another way?
Running Miracle C under Vista
At the command prompt, enter:
input takeown /f filepath <enter>
A message will be display that this completed successfully.
Enter this:
Enter this:
icacls filepath /grant loginname:f <enter>
Next, go to the windows directory, right mouse click on the _default file, select properties, select the Program tab, and remove the checkmark for “Close on Exit.”
Example:
input takeown /f c:\windows\_default
icacls c:\windows\_default /grant torme:finput takeown /f c:\windows\_default
- HP Pavilion
