Dick Blaine
Indexing does not work and "in Control Panel, the Advanced tab is unavailable. The tab appears dimmed, and you cannot select it. Additionally, the Windows Desktop Search service does not start." I have tried several fixes suggested in the MS KB and in this forum but none helped me - all of the fixes seem to be pre-SP1.
My Vista system is: Factory Installed Vista Home Premium 64 bit SP1 with all updates on Gateway 4 core processor and less than three months in use.
When I start Wsearch manually it terminates in about 3 seconds then repeats this in a loop till I disable the service. Tries to remove old catalog and create new one - Fails
One error is 0x80040D23 (Event ID 3026)- insufficient system resources. - Hard to believe with 600GB disk and 6GB memory! Also Event IDs 1008, 1015, 1004 1008 and 7024, 7031 and finally 0x80071a91 appear in varous dialog boxes.
Event ID 1006: The Windows Search Service has failed to create the SystemIndex search index. Internal error <7, 0x80071a91, Failed to save Crawl Scope Manager changes:
