ie8 taskbar icon same as favicon?
darkeale
Is there a way to set the IE8 icon that appears in it's tab on the taskbar so it is the same as the favicon for the site you are currently viewing?
Thanks,
Alex
As far as I'm aware this is currently impossible.
However you can change the IE icon manually by right clicking the IE icon on your desktop, clicking properties and clicking 'Change Icon...' near the bottom of the Shortcut Tab. From here click browse and replace it with any compatible icon file you want.
Sorry, but it can't be done (as to the best of my fairly extensive knowledge)
Oli
    Apple MacBook, 5,1
    Intel Core 2 Duo 2.4Ghz
    4GB DDR3
    Nvidia 9400m
    13.3" Apple MacBook LCD Screen + 22" HannsG DVI LCD + 21.5" Samsung USB Lapfit Monitor LD220
    1280x800 + 1920x1080 + 1920x1080
    SATA Internal 2.5" 500GB (305GB HFS+, 195GB NTFS) External USB 3.5" 1TB (HFS+)
    Aluminium Unibody
    Apple Magic Mouse
    Apple Late 2009 Wireless Keyboard (US)
    6.33Mb/s up. 0.36Mb/s down.
    Harman Kardon Soundsticks II Speakers
