IE not starting up, sorted
HI,
Just got around to updating windows ( Vista 32 ) on my laptop.
Installed sp1 and sp2 from windows update.
All went well, until I tried to open IE, it would not start up.
All I got was a flash of IE on the screen then it was gone.
Turned of all the addons, still no good.
So, went into update history and uninstalled IE8.
All is ok now.
Just thought I would share this in case anyone else has the same problem.
Brian
    ME
    AMD 64 X2 5200+
    ASUS M2N-E SLI
    4 GB CORSAIR CM2X 6400 C5 800MHZ
    PNY Geforce 980GTX+ 512MB DDR3
    AUDIGY 2
    ViewSonic VA2216w 22" wide screen
    1680 x 1050
    2 X SAMSUNG SATA 500GB 1 external usb 500GB
    650 WATT
    IntellieMouse Optical
    Logitech G15
    2mb
Hello Brian!
Thank you for sharing your solution with us :) I'm sure others will benefit from your experiences
Just out of curiosity, why have you not upgraded to IE9?
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Hi Tom.
I just wanted to get IE working again.
I will try IE9 later. Cheers.
Brian
    ME
    AMD 64 X2 5200+
    ASUS M2N-E SLI
    AUDIGY 2
    1680 x 1050
    650 WATT
    Logitech G15
    2mb
Oh right, well I hope it works for you!
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
