IE not responding
sunnystubborn
whenever i start my IE, after couple of minutes it shows not responding..whats the problem wid that..is it due virus?
    Intel® Core™2 Duo Processor P8400
    2.26 GHz
    3 GB DDR2 SDRAM, 2 SO-DIMM slots
    NVIDIA® GeForce® 9300M GS (128 mb)
    14.1 wide
    WXGA:1280 x 800TFT Colour display (Clear Bright LCD Lite)
    250 GB*5 (Serial ATA, 5400 rpm)
    60 kbps
SS
thanks and welcome to vistax64
probably not a virus, but do y ou have a current working antivirus running? what is it?
could you go into event viewer (type event viewer in search) go to the windws log, application tab and look for errors (red "X" in left column). what is the event ID and source of the most frequent?
let me know if you need help with any of this
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
I think this might help you:Speeding Up Internet Explorer 8 | WindowsFixUp
This solution fixed mine:
Alternatively, or in addition to the above fix, you can try registering actxprxy.dll, a process that has improved Internet Explorer 8’s performance for a handful of users.
Click the Start button then search for “CMD.” Right-click cmd.exe and select “Run as Administrator,” then type regsvr32 actxprxy.dll and press return. Quit then re-launch Internet Explorer 8 and check for improved performance.
    Biostar
    Biostar MCP6P-M2
    NVIDIA GeForce 8400GS
    CIBOX
    Hitachi 160GB
Hello Sunny, and welcome to Vista Forums.
You might see if resetting IE8 may help.
