IE Help can not connect to 2 sites
Vista Tim
OK, I am at a lose here. I have an internet connection, it is working and my Vista Home Premium 32 bit has been updated. I can go to every site that I can think of EXCEPT the following two sites:
www.fox.com
www.hulu.com
At first I thought the sites may be down but then I was on IM with a friend and he was able to access both sites.
Every now and then I can get the homepage of Hulu but when I try to watch anything on it all it does is stay on the video loading portion. Fox is never accessable. This started about a week ago (I even rolled back to a different restore point/No Luck)
Does anyone have any ideas?
    Athalon 64X 4200
    MSI K9A Premium
    4gb 6400
    MSI 4850 512mb
    HF 199H
    160gb IDE x2
If you are able to access both sites, but not play their videos, try downloading Mozilla Firefox and visiting them from it.
Hulu could be an issue with Flash -- uninstall EVERYTHING related to flash from your system using the control panel. Visit Adobe - Adobe Flash Player to install the most recent version, and try the site again after restarting.
FOX and other networks use proprietary ActiveX players that can have issues with IE. Trying to view them in Firefox will tell us if that is the issue.
Good luck!
    My own
    Intel Q6600
    Asus Maximus Extreme
    8GB DDR2-800
    ATI Radeon 3870
    Onboard HDAD
    24" horizontal LCD/ 24" vertical LCD
    4xWD Velociraptor (2x Raid 0) 4xSeagate 1TB
    Corsair HX1000W
    Iceberg Liquid
    Thermaltake Bigwater 760is
    Microsoft wireless mouse/laser/ppt remote
    Saitek Illuminated wired
    2x15Mb cbl w/dual NICs/static routing (screw load balancing)
    Mid-level file processing machine; pre-45nm era.
It worked thank you very much
    Athalon 64X 4200
    MSI K9A Premium
    4gb 6400
    MSI 4850 512mb
    HF 199H
    160gb IDE x2
