ICON PROBLEM ! please help
Hello Millenardo, and welcome to Vista Forums.
It looks like you may have used the improper XP method to remove the shortcut arrow in Vista. You can use the program in the tutorial below to restore the shortcut arrow, then afterwards use it to remove it.
http://www.vistax64.com/tutorials/67615-shortcut-arrow.html
Millenardo,
You can try a System Restore using a restore point dated before the icons went wacky on you to see if it can fix them for you.
