I need to know how to do something please Help
I did a accendent I made a supervior password and I need to get ride of it. Mostly cause my aunt is gonna be really really mad at me. Please help.
The Contemplator
Hi Kevin and welcome to Vista Forums
By this do you mean that you have to enter the password when you boot up? Supervisor passwords are usually setup in the BIOS. If this is the case, then there are a number of ways to remove them. You can remove them in the same way that you created them, i.e. through the BIOS interface. Another way is by means of a jumper on the motherboard. By far the easiest - and this is the method to use if other ways don't work - is to remove the motherboard battery, wait a few minutes, and then reinsert it. Of course, if you use either of the latter methods, your BIOS settings will all be set to their defaults, so you will need to re-enter any settings that are not default (you will, of course, need to set the time and date as a minimum).
- Dwarf Dwf/11/2012 r09/2013
- Intel Core-i5-3570K 4-core @ 3.4GHz (Ivy Bridge) (OC 4.2GHz)
- ASRock Z77 Extreme4-M
- 4 x 4GB DDR3-1600 Corsair Vengeance CMZ8GX3M2A1600C9B (16GB)
- MSI GeForce GTX770 Gaming OC 2GB
- Realtek High Definition on board solution (ALC 898)
- ViewSonic VA1912w Widescreen
- 1440x900
- OCZ Agility 3 120GB SATA III x2 (RAID 0)
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
- PSU
- XFX Pro Series 850W Semi-Modular
- Case
- Gigabyte IF233
- Cooling
- 1 x 120mm Front Inlet 1 x 120mm Rear Exhaust
- Microsoft Comfort Mouse 3000 for Business (USB)
- Microsoft Comfort Curve Keyboard 3000 (USB)
- NetGear DG834Gv3 ADSL Modem/Router (Ethernet) ~4.0 Mb/s (O2)
- Other Info
- Optical Drive: HL-DT-ST BD-RE BH10LS30 SATA Bluray
