I need some help
CrazyJim
Hi All,
Please help me!. I have just bought a new pc and its running Windows Vista Home premium Sp1. I am trying to run my favourite game on it - Battlefield Vietnam and it wont play.
I am wondering if this game is supported by Vista. I could really do with some advice on how to get this running.
Thanks in advance.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Hello CrazyJim,
We will need a bit more info here.
What version of Vista are you running ?, x32 x64 ?, and some system specs would help too.
Make sure your Vista is up to date too.
More info = more help. ;)
Also look here, good luck and post your results.
http://www.microsoft.com/windows/co...arch.aspx?type=Software&s=Battlefield Vietnam
I'm not sure which version of Vista I am running, how can i find that out?
The pc I am running is a Packard Bell Ixtreme X6719 UK Model
<LI jQuery1257104662239="340">Operating System
  • Operating System : Genuine Windows Vista® Home Premium
<LI jQuery1257104662239="344">Processor
  • Processor : Intel® Core™ 2 Quad Q8300 Processor
<LI jQuery1257104662239="347">Motherboard
  • <LI jQuery1257104662239="349">Chipset : nVidia nForce 610i (MCP73PV) <LI jQuery1257104662239="350">PCI Express Slot : 1 <LI jQuery1257104662239="351">AGP Slot : 0
  • PCI Slot : 2
<LI jQuery1257104662239="353">Hard Disk Drive
  • <LI jQuery1257104662239="355">Size : 640GB
  • Rotation speed : 7200 SATA
<LI jQuery1257104662239="357">Card reader - Floppy drive
  • Card reader : Yes (21 in 1)
<LI jQuery1257104662239="360">CD-RW/DVD-RW
  • Optical Drive : DVDR+RW+R9
<LI jQuery1257104662239="363">Graphics
  • Chipset : Nvidia Geforce GT220 (1GB)
I am nor sure if my vista is 32 bit or 64 bit. How do I find out?
Right click Computer, and go to Properties, or Control Panel > System. You will see something like this.
Is this the only game that you cant get to play ?. It looks like it will run on Vista x32 but not x64.
I have found in the past that a No CD/DVD patch will help when other solutions wont.
Also make sure your system and games are up to date.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
I would say its probally 32 bit most pcs pre made are 32 bit!
Download the latest patch
Patches and Fixes: Battlefield Vietnam v1.2 Patch Full Install - Demo Movie Patch Download Section - GamersHell.com
then this one
Patches and Fixes: Battlefield Vietnam v1.21 Incremental Patch - Demo Movie Patch Download Section - GamersHell.com
then follow these instructions:
Run your game in Compatibility Mode:
  1. Right-click the game's desktop shortcut icon and choose Properties.
  2. In the Properties Panel, click the Compatibility tab.
  3. Place a check in the Compatibility Mode checkbox.
  4. Select Windows XP (Service Pack 2/3) in the mode box.
  5. Click Apply to save your changes.
If you did not opt to have a desktop icon installed:
  1. Find the game icon listed in your Games directory.
  2. Right-click on the game and click on Customize. This will bring up the Customize menu.
  3. Select Play.
  4. Select Edit.
  5. This will bring up the Properties screen. Click on the Compatibility tab.
  6. Check Run in Compatibility Mode and then choose Windows XP (or whatever operating system the game was designed for).
  7. Press Apply, and then press OK. You will be back at the customize menu.
  8. Close the customize screen.
  9. The game should now be configured to run in Compatibility Mode.
If you're playing multiple games, you will have to configure each game to run in Compatibility Mode separately.
You might also want to try running the software as an administrator by following the steps below:
  3. In the Privilege Level section, place a check in the Run this Program as an Administrator checkbox.
  4. Click Apply to save your changes.
  5. Try the software again.
If u wanna give me some rep click the scales at the top right corner of this post :)
    Intel Pentium Dual Core E5200 Overclocked @ 2.90
    ASUStek
    OCZ DDR2 PC2-6400 Vista Performance Gold 4GB Dual Channel
    ASUStek ENGTX275 PCI-E x 1
    19inch benq
    1400x900
    400 gb
    700 Watt artic power
    Artic cooler
    4.70 mb/s download, 0.37 mb/s upload
