Solved I need some help...
Chicago Dave
I have recently started using Windows Mail and I wanted to know if there is a way to change a setting or something like that so I can run it in the taskbar and when a message is received it either give me a bubble notification or plays a sound.
Thanks for an help.
    Hp Pavillion dv6835nr
    Intel Core2 CPU Duo T5550 @ 1.83GHz 1.83GHz
    3GB
    15.4"
    250GB HDD 320 WD External HDD
    Swis Army Travel Bag
    Synapatic Touch Pad
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
Thank you VERY MUCH I can be more productive when working and not have it to be a hassle.
    3GB
    15.4"
    Synapatic Touch Pad
Side question: Will i still receive notifications if I only have the tray control (WinMailTray.exe) running?
    3GB
    15.4"
    Synapatic Touch Pad
Information
This program will add a system tray icon that will allow Windows Mail to be minimized to the tray icon allowing you to be notified of new messages without Windows Mail being on the taskbar.
The copy above, from the top of theTutorial, should answer your question.
Please confirm that this is correct.
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
Re : I need some help...
Still window not provide this type of any settings and they also not provide any other taskbar as per your requirement is also not use in market.
Ok it's working fine, thanks.
    3GB
    15.4"
    Synapatic Touch Pad
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
