I need help ! URGENT
FallenSatan
Hey guys I reformatted my computer ( By myself ). Before I refromatted my computer had about 150gb of space in (c) and now it has only 50gb can someone tell me what happned?
THANKS
Instead of breaking your head on your computer, Call your local Computer Tech. Say him your problem and mostly he will just say to bring it to him. It will cost you from 20-50$ and your memory will be back.
Hi FallenSatan,
Hard to be sure without knowing which program you used, or exactly what you did.
It may be you deleted 100gb thereby making it unallocated space - leaving you with a partition of 50gb free.
In that case it should be easy to create another partition and format it as NTFS, or extend the 50 gb out to the full 150gb - whichever you prefer.
See these tutorials
http://www.vistax64.com/tutorials/95398-disk-management-shrink-partition.html
http://www.vistax64.com/tutorials/95418-disk-management-delete-extend.html
If you need any more guidance, feel free to ask.
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
THANKS
Hi. Seems as if you had 2 partitions on that drive. Just go ahead and format the other partition. I'm cannot be certain that you've done just that, but there's a 90% chance that your drive had 2 partitions (for example C: and E: )
    Asus. My own build at home.
    AMD Athlon 64 X2 6400+ Windsor 3.2GHz Socket AM2 125W Dual
    ASUS M3A79-T Deluxe AM2+
    OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
    Radeon HD4870 X2 2GB 512-bit GDDR5
    ASUS Xonar D2 7.1 Channels PCI Interface Ultra Fidelity
    Dell standard CRT 17 inch screen
    1024 x 768
    4x RAID10 array: Seagate Barracuda 750GB 3.0Gb/s
    Coolermaster HAF
    Air
    Logitech standard mouse
    Logitech standard keyboard
    Too slow. I'm going to move soon just because of my net.
    I build computers as a passion and for business.
I agree with all above. Open Disk management, and there should be one drive listed. In that drive, there will probably be one partition of 50gigs and about 100 gigs of unallocated space. You should be able to merge the two together, giving you all 150 gigs.
~Lordbob
P.S. @GLOBES: not necessary, unless there is nothing listed in disk management.
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
