I`m having problems with my HDD Driver
AlOnan
I opened Disk Management Console and Disk 0 just didn`t show up!!! I checked Device Manager and my HDD Drive is missing, what can I do??? Can anyone help????
    Acer Aspire M1641
    Intel Dual Core E2220 2.4GHZ
    2GB DDR2
    ATI Sapphire Radeon HD 3450 256MB PCI-E 2.0
    Philips 192E WideScreen LCD Monitor 18.5`
    Seagate ST3250318AS, Western Digital WD3200AAJS-22L7A0
    2048kbps downloading, 512kbps downloading
    Planning to Upgrade my PC...
Will anyone help me??
    Acer Aspire M1641
    2GB DDR2
Could you Upload us a Screen shot of Device Manager This will Help us determine the Problem
Hope This Helps,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Also could you Fill in your System Specs a bit more and Provide the Name of your HDD
To find out your Specs You can Download Speccy to Obtain this Information
see Speccy - Download For The Download
Hope This Helps,
Josh
    AMD HD Radeon 6870
    Novatech Night
My HDD is a Seagate ST3250318AS 250 GB 7200 RPM!!!!
    Acer Aspire M1641
    2GB DDR2
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
Thanks but my the problem is at my HDD Drive and not at my DVD Drive!!!
    Acer Aspire M1641
    2GB DDR2
Go in Device Manager and uninstall the drive and restart the machine.
When the machine restarts Vista will find and reinstall it.
If its not listed in device manager, you have more of a problem than Vista.
Check your BIOS settings for the recognition of the Drive. Also Are you using the Drive? Is Vista on that Drive? If Not Check for Loose Connections
Hope This Helps,
Josh
    AMD HD Radeon 6870
    Novatech Night
Yes, my Vista is installed on that HDD!!
    Acer Aspire M1641
    2GB DDR2
Okay Could you please reinstall the driver for the HDD
Many Thanks,
Josh
    AMD HD Radeon 6870
    Novatech Night
Thanks!!
    Acer Aspire M1641
    2GB DDR2
I know but if you actually read the link you will see what ShadowJK said to do, and I see you have done it anyway after Shadowjk told you to. From the link.
"Go in Device Manager and uninstall the drive and restart the machine. When the machine restarts Vista will find and reinstall it.
If its not listed in device manager, you have more of a problem than Vista."
    LENOVO 64734VM
    15 inch
If you Read the Post you will find that the steps to repair the Problem with the DVD Drive are the the Same steps to Repairing any Drive
    AMD HD Radeon 6870
    Novatech Night
Maybe i should format my PC, because the problem is not in the BIOS!!!!
    Acer Aspire M1641
    2GB DDR2
Did you uninstall the driver? Also do not format yet because it is a driver the problem may still exsist after the Format
Many Thanks,
Josh
    AMD HD Radeon 6870
    Novatech Night
I said that the HDD Driver is not listed in Device Manager!!
    Acer Aspire M1641
    2GB DDR2
