i have no sound
a880tt
i had sound day before yesterday on my pc
i switched it on today and i have no sound
the only time i have sound is when i put the pc to the hi-fi via the aux.
any idea please
thanks
ive got vista 32 i think and its a real tech hd sound card :D
To check your playback devices:
Click Start, type sound in the search box , then select Sound in the results listing.
Right click a device and select the option to Configure and then Test each device, when you're finished, ok the dialogue box .
Click Show Disconnected Devices to see what's listed there.
To Check Volume Settings:
Click Start>Control Panel>Hardware and Sound>Adjust System Volume
Drag slider up or down for more or less volume.
Click mute button underneath slider to see if it's muted.
Hope this helps
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
hi i have tried this and it all works perfect when i run the pc through the aux on the hifi
as soon as i want to play the sound through the pc it doesnt work.
but the equalizers go up when i play some thing.
ive uninstalled it a re booted the machine
still not working :cry:
Have you a Laptop or a desktop PC?
when you are trying to play the sound through your computer where should the sound be coming out, ie have you external speakers attached to your computer and if you do, do they have their own independent power supply ie a plug to the household power electricity?
Best and Warm Regards
Adrian Wainer
    self build desktop PC
    AMD Athlon 64 4800 dual core Toledo 2.4 gigahertz
    Asus A8N-SLI Deluxe
    4 x 1 Gigabyte sticks
    Gainward 7600GT Golden Sample factory overclocked
    Realtek onboard sound AC-97
    View Sonic G90B 19 inch CRT [ 17.7 visible ]
    1600 x 900
    Hitachi HDT725032VLA36 quantity 4
    Cooler Master Stacker
    Thematalke Big Typhoon air cooling
    Microsoft Intelli mouse optical tracking
    Mitsumi
    3.6 Mbps HSDPA
I assume you use a minijack lead from the light green output socket on the back of your pc to the back of your monitor.
Try using the same lead and socket into your hi-fi to check they work.
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
SIW2
If you use such a lead to connect the computer audio output to your monitor and you try connecting your computer via that lead to the Hi-Fi and it works okay, that means that everything is good as far as the end of that lead, and in that case it looks like you have a problem somewhere in the monitor.
Adrian Wainer
    Asus A8N-SLI Deluxe
    1600 x 900
    Mitsumi
    3.6 Mbps HSDPA
Exactly, it would obviously mean the sound signal was coming out of the pc fine and the output socket and the lead are fine .
The problem would be further down the line e.g. connector on the monitor , or inside the monitor itself.
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
