I have Ad-ware please help me remove!
nbkp
Hi.
So the story is, I have loads of ad-ware and viruses and its starting to p*** me off. I have been using SpyBot Search& Destroy, but now for some reason it won't open anymore, neither will Norton AntiVirus.
I have tried the Kaspersky online scanner but that didn't seem to work either.
Can somebody recommend me a program to use that will work?
Thanks
    Laptop-Sony Vaio VGN-FW351J/H
    Intel(R) Core(TM)2 Duo CPU T6400 @ 2.00 GHz
    Intel GM45/GM47
    16.4"
    1600 x 900
    320 GB - Serial ATA-150 - 5400 rpm
    Standerd Lithium Ion Battery=2 Hours and 30 Minutes
    Titanium Gray
    Air Cooled
    V220 Cordless Optical Mouse for Notebooks
    1.58 MB/S Download .94 MB/S Upload
    Blu-ray combo drive, Webcam, and HDMI Output
    E8400 oc'd @ 4.0Ghz
    EVGA 780i
    4GB Corsair XMS2 Dominator
    ASUS EN9800GX2
    Auzentech X-Fi Prelude 7.1
    Acer 19'
    74 Gb WD Raptor for OS 2 x 150 Gb WD Raptors in RAID0 for Games 500 Gb Seagate for storage
    Enermax Galaxy 1000W
    Mountain Mods U2-UFO
    Swiftech & Thermochill Watercooling
    Razer DeathAdder
    Logitech G19
nbkp,
I suggest that you run the Windows Malicious Software Removal Tool. Perform a Full scan. Reboot at end. Refer both links.
Download details: Windows Malicious Software Removal Tool
The Microsoft Windows Malicious Software Removal Tool helps remove specific, prevalent malicious software from computers that are running Windows 7, Windows Vista, Windows Server 2003, Windows Server 2008, Windows XP, or Windows 2000
Certainly use SuperAntiSpyware. If you can't get it the way whs recommended use this link - SUPERAntiSpyware.com - Online Scanner Reboot at end.
Use Malwarebytes as well. [link as per post above]
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
Sounds like you have a nasty trojan my coworker got. It would shut down everything before it could finish a scan. Then the trojan would change it's name. It lives in you registry. He called Eset since we are a paying business. It took about 2 hours to work around it and find a program that the trojan could not shut down. At that point it was quarantined and finally removed by Malwarbytes. Good luck.
    Cyberpower
    AMD Phenom X4 9850
    MSI K9N SLI V2
    8 GIG DDR 800
    EVGA 9800 GT 512mb
    onboard
    SyncMaster 220wm
    Hitachi something or other 500 gigs
    650 watts
Just a passing note. the only way to be absolutely sure is to do a clean install, and then run a system wide (including data disks) scan with a current anti virus.
its a pita but I have helped more ppl than i can count hwo re-installed the same software that had given them the trojan in the first place.
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
ken
I agree with this comment. In the final analysis it would save time & limit one's frustation.
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
