I got a problem with vista sleep
slix122
Everytime i go away for 1-2 hrs and i come back when vista is on sleep i cant wake it up.. everything is frozen , mouse keyboard, it pisses me off. the only way to get out of it is to turn it off. If i click on the button once, ill see my screen again but my mouse and keyboard still wont work so i have to click on it again. Also, i love vista, a new problem has occur, now from time to time my screen decides to black out for a sec then come back then black out as it wishes. Can anyone help me please? i never Ever had any problems with Xp. I tryed looking online , but they all speak in a foreign language. Thanks!
Is it a new installation of Vista? Is your computer a laptop or a desktop? Did you buy the computer pre-built from a shop/store or upgrade an existing computer (ie windows XP upgraded to Vista)
    Wired2fire custom evolution
    Core2Extreme X6800 @ 2.93ghz
    Nforce 4 SLI 16x
    Corsair DDR2 800mhz x 4gb
    XFX Nvidia 260gtx SLI
    Soundblaster Audigy 4
    Dell 24inch
    1920x1200
    Western Digital Cavier 500gb Western Digital Raptor 150gb
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
    Saitek Gamers Keyboard
    Its getting old, been upgrading it over the past few years, mainly the ram and the gpu's. Will hold out till some next year before I build another one.
Well i bought the cd around 1 year ago , it didnt show any problems back then, well.. it was kinda slow, i must of formatted twice or thrice. The only thing i remember adding is a 1 GO DDR2, its a desktop and i bought it at a shop, the only thing i kept from my old pc was a hard drive, everything else was new, but my computer is 3 year old thats when i had XP installed, if you need any more info let me know! ty
Hi Slix122
So youve been using vista for about a year, reformatted a few times during the time youve had it? Have you been updating your drivers yourself?
I find alot of problems are related to drivers and how they are installed, especially if you have installed newer drivers over older ones without removing them first. This is especially true of graphics drivers. I have a feeling yours is related to graphics drivers based on the screen going black and coming on again. What are you system specs?
    Nforce 4 SLI 16x
    Dell 24inch
    1920x1200
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
Yea i was updating the drivers myself, i dont really know where they are tho, i dont know if it has anything to do with the flashing screen but i remember there being an update for Nvidia , was 103 mb and it didnt start so i clicked escape, 2 minutes later i saw my screen flashing, must of been a coincidence. But do you think that the way i installed my drivers affected the vista sleep mode too ?
Sorry about this, i dont really know a system spec is? like my video card name , mother board, how much memory i have and everything? is there a way to see it from my computer ,or do i have to open up my computer too see all the information? thanks!
Hi Slix. I think it is quite likely related to the graphics driver not being fully installed/updated.
Click on your start menu and in the search box type dxdiag.
The Direct X Diagnostics tool will show in the taskbar. Click on it to open it.
Once the Direct X diagnostic tool window opens, it may ask you if you want to check to see if your drivers are digitally signed. Just say yes. if not read on:
Let the tool complete its check of your system. Its progress is visible at the bottom of the window above the help button.
Once complete, click on Save All Information button at the bottom of the window. i would recommend saving it somewhere you can locate it easily like your desktop.
The information from the Direct X diagnostic tool will be saved as a text document (txt) which we can open with notepad or wordpad afterwards.
Upload your saved Direct X Diagnostic report here so I can see more information about your system.
    Nforce 4 SLI 16x
    Dell 24inch
    1920x1200
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
A second choice would be to download a tool like Belarc Advisor or What's Running. Both are free tools and give you alot of information including (Belarc) if you are missing updates. You can put a shortcut on your desktop to run it every so often.
    Self Build
    Intel Core 2 Quad Q6600 Kentsfield 2.4 Ghz LGA 775 Quad
    Foxconn P45A-S LGA 775 Intel P45 ATX
    OCZ2VU80016GQ 16GB (4x4GB) DDR2 800Mhz Vista Dual Channel
    2- Sapphire 10022SL Radeon HD 3850 PCI-e in Crossfire mode
    Acer H213H 21.5" Widescreen Full HD 1080P LCD
    2- Seagate ST3160023AS HD 500GB 2- Seagate ST31000333AS HD 1TB 1- Seagate ST310005FJA105-RK Freeagent Desk 1TB
    Enermax EG701AX 600W Switching Power Supply
    Lian Li PC-70 Ext/ATX
    Artic Cooling Freezer 7 Pro for Intel CPU
    Intellimouse Optical
    MS Keyboard Pro
    3766.5Kbits 470.8KBytes
    2- Incessa IN-811 removable drive bays and 8- removable drive bay caddies.
I wont copy paste the entire log because i have like 6 pages, i will try to put all the info that matters.
System Information
Time of this report: 12/13/2009, 13:24:25
Machine name: SLIX-PC
Operating System: Windows Vista™ Home Premium (6.0, Build 6002) Service Pack 2 (6002.vistasp2_gdr.090803-2339)
Language: French (Regional Setting: French)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz (2 CPUs), ~2.4GHz
Memory: 2046MB RAM
Page File: 1410MB used, 2924MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
DxDiag Version: 7.00.6002.18107 32bit Unicode
Display Devices
Card name: NVIDIA GeForce 7600 GT
Manufacturer: NVIDIA
Chip type: GeForce 7600 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0394&SUBSYS_760D1043&REV_A6
Display Memory: 1016 MB
Dedicated Memory: 248 MB
Shared Memory: 767 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor: Generic PnP Monitor
Driver Name: nvd3dumx.dll,nvd3dum
Driver Version: 8.16.0011.9107 (English)
DDI Version: 9Ex
BGRA Supported: Yes
Driver Attributes: Final Retail
Driver Date/Size: 9/27/2009 23:12:22, 9441384 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B72E3E-40D1-12CF-6150-06A21EC3C535}
Vendor ID: 0x10DE
Device ID: 0x0391
SubSys ID: 0x820D1043
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_B ModeWMV9_B ModeVC1_A ModeWMV9_
Deinterlace Caps: plentyy randomkeys..
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
the other thing is about the sound device , usb device ,direct input device, gameport device, ans plenty of other things i dont think is relevant, if i missed anything important let me know.
Btwn i really appreciate your help!
Okay this is the latest 7 series driver for your card (in case you dont have it already)
NVIDIA DRIVERS 195.62 WHQL
Download it somewhere like your desktop where you can access it easily.
Also download DriveSweeper here and install it before you follow the rest of this advice.
Guru3D - Driver Sweeper (Setup) download from Guru3D.com
Next, type msconfig into your windows start search box. Run the system configuration tool when it appears in the startmenu.
Once open, select the Boot tab and at look at boot options.
Check the Safeboot box, click apply, OK then restart the pc.
When your back in your desktop in safemode, open the start menu again and type device manager in the search box. Open device manager once it appears in your start menu.
In device manager look down the list of components for Display adapters. Expand it to show your 7600GT. Right click on it and and select uninstall. The unistaller may ask you if you want to delete driver software. Say yes and wait for your drivers to be taken off.
Once finished, restart the computer and let it boot up again into safemode. When your back to yourdesktop, run Drivesweeper. You will see a window with a list of driver manufactures and driver types. Select NVIDIA-Display and click on Clean at the bottom.
A popup window will as you if your sure you want to continue. Say yes and let it clean out residue driver traces (usually in system32 folder and the system registry).
Drivesweeper should automatically ask you to restart the computer once its finished.
After your computer restarts, run the Nvidia Driver Installation you downloaded above. Install it but this time, before you restart your computer, click start and run msconfig again. Go back to Boot tab and uncheck safeboot so your computer starts in normal windows mode. Apply and restart.
You should be good to go when it starts up again. You can access the NV Control panel by rightclicking your desktop. Run it and set your display to your preferences. The control panel usually automatically sets your screen resolution according to your monitors native display settings. Hopefully this should sort out the prob. Let us know how you get on or if you run into any problems.
    Nforce 4 SLI 16x
    Dell 24inch
    1920x1200
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
Hmm nope that didnt fix it :( 5 Hrs ago, i left my computer open and i went to work, when i came back i thought that someone closed my computer because it didnt make any sounds at all! So i clicked on the power button and right after that my screen opened and the page that i was on was still there, It was showing the time 22:30 45 seconds and i was able to see the seconds go up and i could see the time on windows worked too but i wasnt able to use my keyboard or my mouse. With that conclusion, i dont know how but somehow, when i left my computer open for too long all of my ports seem to stop working but my computer is still functionning( by the way the flashing screen still happen , it seems to do that the first minute of when i start my computer.)
If you followed the above advice to the word, we can safely say its not related to your graphics drivers. So your screen flashes everytime you turn on your computer? What kind of flashing is it? Is it intermittent or does it just flash once? Does it continue to happen afterwards or only once at the beginnning.
With regards your devices (keyboard and mouse) not working after sleep mode, Ill have to get back to you on that. Let me digg around abit see what I can find out.
UPDATE theres an article here and a hotfix by MS
http://support.microsoft.com/kb/929734
    Nforce 4 SLI 16x
    Dell 24inch
    1920x1200
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
yea i followed everything by the letter and well it only seems do flash 3-4-5 times when i start my computer but after a minute it stops, i guess its not really important, it used to do it more than that but it doesnt seem so, as for the sleeping mode i dont see anything for saving my registry, i see windows xp , windows xp familliale but not vista lol, its gonna take me forever to fix that problem, so many steps ;P
