I cannot connect with wireless
OogahBoogah
Hello guys I have a wireless modem but unfortunately i m connecting with cable
because when i try to connect its just dont work I try to fix it with internet company we tried lots of ways( changing password or WPA to WEP) but at last we cant fix it they told me its something wrong with my computer BUT I used wireless al the time when i m not in home
my modem is Airties rt 210
and I m using vista 64bit
Thanks for helping
Have you tried to uninstall adapter and then re-install adapter.
Have you got an old wireless router you can try?
Try old router 1st then if that connects then new router required. If it doesn't connect then it is likely to be the PCI board in your computer.
    Intel Core 2 Quad Q6600 G0 St
    Asus STRIKER EXTREME 680I SLI
    Corsair 4GB Kit (4x1GB) DDR2 800MHz/PC2-6400 XMS2 Memory
    Point Of View 8800GT 512MB GDD
    Soundmax 5.1
    Samsung 46"
    1080P
    1x WD Raptor WD360ADFD 36GB SATA 10KRPM 16MB Cache 1x WD Raptor WD740DFD 74GB SATA 10KRPM 16MB Cache
    Coolermaster 600W
    Coolermaster nVidia
    Arctic Cooling Extreme
    MS Wireless Laser mouse 8000
    MS Wireless Entertainment Keyboard 7000
    1.2mb & 10mb
How can i uninstall adapter i didnt install anything ?
Unfortunately I dont have other wireless
Your ISP obviously tried everything they knew to fix this problem and as far as their concerned its one of two things.
1. The PCI card or 'Adapter' in the back of your computer is Broke.
2. Your router is broke.
For the latter are all the lights working on your router including the wireless light.
If so, then more than likely to be PCI card at fault.
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
What country are you in now?
If you are in a different country there maybe a compatability problem.
The adapter works for the USA guidelines but probably not for the (whatever country your in now) guidelines.:huh:
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
Ok that maybe your problem then. There is probably a compatability issue with the PCI card. You will need to buy a PCI card in Turkey. That shouldn't cost you much more than 30 Euros...:)
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
Do you find any Networks while trying to connect to your router?
Should have asked this question 1st..............
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
So it's the router then!:)
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
have you tried turning wireless security off and trying to connect?
    Toshiba Satellite L330-1CU
    AMD Dual Core 2.1GHZ
    2GB RAM
    250GB
    8MB
what should i do then :) ?
Inform your ISP that the fact remains that your computer sees other wireless routers so the problem definitly lies within their
router...Ask them to send you a new one. New wireless routers do fail as mine failed after having it for only 2 weeks.
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
