How well will Assassins creed run with these specs?
hopishaman
I have vista 32bit home edition
2.5gb ram
Intel(R) D CPU 3.00GHz
512mb Geforce 9800GT PCI-E
80GB disc space
Will this game run ok on these specs?
I'm not expecting to run it on its maximum graphical settings but i also dont want to run it at its lowest either as ive seen it played on lowest on a friends computer (hes using a 6800gs if i recall correctly)
my friends gameplay is so laggy i could hardly bare it...fingers crossed it will be fine on mine...
At a glance it should work with no problems at all even in DX10
but dont jump in with all 4's just start with basic settings and creep them up till you happy
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
i made a user just for you,
i have
Mobo: Asus P5N32-SLI SE Deluxe
Chipset: NForce4 SLI 16X Intel Edition
CPU: Intel Core 2 Duo E6600 @ 2.4 GHz
GPU: nVidia, XFX GeForce 8600GTS XXX X2 SLI 16X
PSU: Thermaltake Toughpower 650W
HDD: 2x Western Digital, Serial ( ATA ) 2 320GB
Memory: X2 Corsair XMS2 1GB TWIN2X1024-6400C4PRO 800Mhz
OS: Microsoft Windows Vista Ultimate 32bit X86
and running Assassins creed at 60fps on dx9 full graphics
and running at 25-50fps on dx10 full graphics
your rig is better then mine, it will work just fine!
i thought i wouldn't get high fps at dx10 with highest graphics but i did, (because the SLI...) i have framedrops to 25 but avrg of 40fps dx10 and 60fps at dx9
by the way, it's all about the forceware settings, AA (2x-16x) and Super\Multi sampeling
tip for this game, dont put the crowd density on full, its overpopulated to the point of tripping into people at every corner, the setting just below full is perfect.
    §ĮŁΣNŦ Д$$Д$$ĮN
    Xeon X3360
    P5W64 WS Pro
    EVGA Geforce GTX470 SC+
    Samsung T200
    WD 1TB RE3
    Thermaltake Toughower 750w
    NZXT Lexa Silver
    Zalman CNPS10x Extreme
    Razer Deathadder 3500dpi
    Razer Lycosa Mirror
    24Mb/s
i have
Ummm his system says Pentium D dual core 3ghz....thats way slower than a stock E6600 Core design....although the 9800 will make up for it. :p
    Intel Q6600 @ 3.6ghz per core (OC)
    MSI 965 Platinum at 400FSB (OC)
    Corsair XMS2 4gig PC6400 @ 800mhz
    Nvidia 8800GTS 640mb using 178.15 driver
    Audigy 2 ZS
    Samsung 22" LCD
    2x Seagate Sata-II
    Seasonic 650W
    XCase Alien
    Zalman 9700 CPU Cooler & 250mm Side Panel, 2x 120mm Case
    Razer Diamondback 1600dpi
    Logitech G11
    10mb Down 1.5mb Up Actual speeds (24mb package)
    Compro PCIE Dual DVB-T
Hell i have Assassins Creed on full graphics with my rig. Your 9800 will definitely make up for any CPU bottleneck (when i say definitely im not actually sure).
Then again is have a Core 2 Duo OC, 8800GT OC, 4GB ram, 2x500GB HDD's...
ummmm yeah
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Coolermaster Silent Pro 700M
    Antec 900
    Tuniq Tower 120 LFB
    Logitech MX400
    Logitech EX110
    Graphics Driver - 190.38
The Pentium D WILL be the bottleneck. The card may help a bit, but not a lot.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
I have a problem running games on my PC, one of which being Assassin's Creed. Here are my specs:
Vista Home Premium 32bit
Intel Pentium Dual-Core Processor T3200 (2.0 GHz, 667 MHz FSB,1 MB L2 cache)DVD-Super Mulit DL
358 MB Mobile Intel Graphics Media Accelerator X3100
3 GB DDR2
250 GB HDD
When I try to run it, an error message pops up saying that a problem has occured and the program must end. Please help!!!
3 GB DDR2
250 GB HDD
Yeah i bolded your problem. You are running off integrated graphics.........:eek:
Good luck trying to run anything other than flash games on the internet. AC is a newer game, and i dont kjnow what it requires, but not integrated graphics.
Are you running a desktop or laptop? If you are using a desktop, and want to game, seriously consider buying a graphics card. I just bought a 9500gt 1Gb on sale at Fry's for $40... A $100 card! Great deal. If you want to game, consider buying a good card, minimum GeForce 8 series or better.
~Lordbob
EDIT: I dont know what is causing the error, except maybe not a good enough graphics card. Possibly it needs DX10. Dunno.
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
No matter how good of a video card you have, your processor is the biggest problem in this game.
For an example i have a radeon hd4870 which killes a 9800
but my processor is a phenom 9100e quad only running at 1.8 ghz and i get a bad frame rate no matter what settings its not my video card which plays crysis on high
Hi there. I also have a problem with installing Assassin's Creed I, I'd be extremely grateful for any advice...
Here is my spec:
Intel Core 2 Duo Processor T7500
(2.20 GHz, 800 MHz FSB, 4 MB Cache)
Vista (R) Home Premium
4 GB Memory
320 GB Hard Drive
ATI Mobility Radeon 2600 XT
I'm guessing it's a problem with the video card because when I do install it, I can't see the character move about. It's just a grey, washed out screen. It's weird because the cut scene right at the beginning shows perfectly. But as soon as you have to do the tutorial bit at the start, that's when there is no image.
Also, upon installation, a dialog box does come up saying that my system meets all the requirements to play the game (all green ticks). It's all very confusing and frustrating! Can anyone possibly help me?
-Alison-
Hello Alison S,
Make sure your Video drivers are up to date, and also, make sure you are running it in DX9 mode.
Hope this helps, good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
3 GB DDR2
250 GB HDD
not sure about your problem, but no way can you play any new-ish games with a laptop with integrated graphics. check out my specs, i can barely run Spore at 15fps (or thereabouts) with medium graphics.
(decent screen for movies though :p)
    Acer 5735z Laptop
    2.0 ghz intel pentium dual-core processor t4200 800mhz fsb
    Acer CathedralPeak Rev
    4gb
    Integrated Intel Graphics Media Accelerator 4500
    Realtek
    15.6" HD CineCrystal LCD
    1366x768
    160gb stock drive. ATA
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
You will need at least 256MB of video memory to run the game at decent settings. Some integrated graphics will run the game but most if not all of the Intel Graphics wont. They have 64MB dedicated and the rest are VRAM. The Radeon HD3000 Series has 256MB dedicated with up to almost 2GB available.
Back to the original post,
The game should run fine. Just dont try multitasking while playing. Dont have the internet or aim or applications like that running in the background. It will kill the performance. The Graphics should pull you through pretty good but dont push to max. Running at medium you should do nicely.
    HP Pavilion DV7-1129wm Entertainment PC
    AMD Turion X2 RM-72 Dual Core @ 2.1GHz
    2 x 2 GB Hyundai DDR2 400 MHZ
    ATI Mobility Radeon HD 3200 @ 256 MB
    IDT High Definition Audio/SRS Premium Sound/Altec Lansing
    17" Laptop Screen
    1440 x 900 laptop, external 17 in LCD 1024 x 768
    WD Scorpio Blue 320 GB SATA 5400 RPM Toshiba 68 GB SATA 5400 RPM Second Drive (backup)
    8 Cell Lithium Ion Battery
    Laptop with "light up" HP Logo on outside
    Insane air coming out of Targus dual fan cooler
    Microsoft Wireless Mobile Mouse 3000 / Touchpad
    Full Keyboard with numpad
    Comcast Cable 20 MBps
    Used Primarily for CAD design using SolidWorks 2010. Also I love to watch HD movies using the HDMI output(Netflix). Linked to my Xbox 360 for Windows Media Center 3 USB ports + USB/eSata HP Remote for Windows Media Center and Quickplay Internal Dual Layer DVD+/-RW External HP Lightscribe Dual Layer DVD+/-RW HP Webcam and Microphone
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Hello... I have..
3 gig ram.. ( actually 4gig.. but due to x86.. it takes up 3gig..)
2.93ghz intel core 2 duo e7500
500gb WD sata
how ill assassins run on my pc??
and i want to run F.E.A.R. and godfather 2 also..
please help.!
    Intel Core 2 duo E7500 @ 2.93Ghz
    Intel DG41RQ
    Kingston 4GB
    9400GT 1GB
    Onboard [Realtek High Definition Audio]
    Samsung 22" LCD
    1920x1080
    500GB SATA Hitachi
    iball cabinet
    microsoft
    microsoft internet keyboard
@smarteyeball
hey.. /// u have vista ul x64.. and windows 7 x64.. WOW.. i was just trying to find a person with these...
how are these windows giving u gaming performnace.. i have given my specs... plz tell.. i have 7 and vista x64 setups.. which one shud i install for gaming..!! smarteyeball plz help..
    Intel DG41RQ
    Kingston 4GB
    9400GT 1GB
    Samsung 22" LCD
    1920x1080
    500GB SATA Hitachi
    iball cabinet
    microsoft
