How to set up permanent Administrator privileges for Finale
Florio
Last week I got rid of Comodo Firewall and am now using just the Vista Firewall. The problem is that this has created problems with Finale 2008, the music notation software I use. The 'Help' function, which previously connected directly to internet, no longer works; instead, Explorer Resources opens and I have to manually choose from the many help files available the one that is to be consulted.
I've discovered that by right-clicking with the mouse on the Finale icon before opening the program, and by running as administrator, then the 'Help' files open properly. How can I set up Windows firewall so that Finale always runs with Administrator privileges (I am in any case th Administrator and only user of this laptop)?
Florio
Right click on the shortcut and goto the properties then click on advanced then check run as admin then ok and it should run without any problems.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
