Solved How to lock vista without sleeping?
fields999
Ok hi,
Sorry if this question is a bit dumb but...
Is there any other way to lock vista without going into start menu and clicking on lock this computer, as i want to have it assigned to a multimedia key on my keyboard.
Like theres a sleep button on my keyboard, but when i use it, it sleeps, dissconecting me from the net and etc so my downloads will stop.
Just want to be able to have a key that when i press it will just lock the screen of my pc and thats all.
If anyone knows how to do this that would be great!
thanks
    HP / Custom Build
    AMD Phemon 8650 2.3ghz X3
    Nvidia nForce 720a
    8GB DDR2
    ATI Radeon HD 4650 1GB
    22" HP w2216v
    Hitachi 500gb - Seagate 500gb - Western Digital 1TB
    Cooler Master 600w
    HP
    3x 120mm 1x 90mm 1x 80mm Fans
    Microsoft Explorer Mouse
    HP Multimedia Keyboard
    24mbit
Thanks but is there anyway to change this hotkey?
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
Hello Fields,
You can create a Lock shortcut to use. You can then place it in Quick Launch, or where you like, for easy use of it.
If you place it in Quick Launch as one of the 1st 10 icons, you can use the Windows Key + (1 to 0) to open it.
You can also add a keyboard shortcut of your own to the Lock shortcut using step 4 and on from this tutorial.
thanks i got the keyboard shortcut working now
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
You're welcome Fields. :)
Hello Fields,
I didn't know that thanks Shawn. :D
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
You're welcome Stephen. :)
