Solved How to launch the "right" explorer.exe
Sopuli
Everytime my explorer.exe crashes it normally turns itself up but when it doesn't i end up executing it manually from task manager which leads to my desktop icon placements getting messed up. Now if i reboot my computer the grid placements are normal again, what's up?
Edit: I'm now using UltraMon which does the job wonderfully
What are you doing when it crashes and how often is it doing it?
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
There are plenty of icon position save restore freewares around. For 32 bit I have one where you right click the Destop to save or restore. But there are other more sophisticated ones. Try the big download sites. But ilikefree is right. Find out the cause.
After messing around with desktop icon positions I got so sick of it I kept none on my desktop. I started using launchers like RocketDock. Much cleaner with no desktop icons, except temporarily for a download or whatnot.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
Use a program like DesktopOK top remember icon placement on the Desktop. Then it's easy to restore them if they get messed up.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB Seagate ST2000NM001 2TB Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot) Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
