How to Export Hard Drive to Laptop?
Bud
I would like to download or export my Desktop Hard Drive to my new Laptop. How? I have wiiFi Modum, do I need any cables? Thanks
Another question since I have not received an answer to the question above. How do I remove the harddrive data should I need to take back the puter?
How about copying the data that you require from your desktop HDD onto a USB memory stick (you can get 16GB models now) and then plugging this in to your laptop?
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
You can only move your user data, not the system. And you cannot move large amounts of data via the WiFi - at least not in any reasonable amount of time. Take the advice of Dwarf and use an USB stick or an external disk.
    Dell
    Q6600
    HP w2207h
If you want to prevent any of this information remaining on your laptop, make changes to the data on the memory stick. Remember that you have the original version of this data on your desktop should you need to restore it for any reason. To remove any further traces of it from your laptop, install and run http://www.vistax64.com/software/86472-latest-ccleaner-version-released.html Amongst its options is one which clears your MRU lists (Most Recently Used) in your registry.
    Gigabyte IF233
    Dell
    Q6600
    HP w2207h
