How to enable Autorun with a specific program?
dubnikova
I've an integrated CF reader (always drive G.) in my new Dell XPS Studio. Whenever I insert the CF card I would like a certain program (Nikon Transfer) to start? The autorun screen that is invoked when I insert the card has no option to add this program.
Avi
Avi
Open Notepad, then copy & paste the following:
Code:
[autorun]
OPEN=SETUP.EXE
ICON=SETUP.EXE,0
Obviously, change SETUP.EXE to the name of your program EXE file.
Save the file as "autorun.inf" into the root of your CF card.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
Thanks for the prompt reply, but is not a very good solution. Since I format the cards once they full with images. I need to do something on the drive level.
AD
AD
That is the only way to enable Autorun for any particular device. :(
I wish I could help further, but that's it...
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
