How should I connect my PC to TV
SevenoakBoy
What I want to do is:
Connect my Vista Media Center PC (located upstairs) to my 1080P LCD TV (located downstairs), the cabling distance between PC and TV is 12 mtrs.
Advice
I need advice from those with experience in setting up similar PC to TV connectivity. How to connect; quality of cables; signal over distance; etc. I have discounted wireless due to issues with signal reliability
PC Spec
Triple TV Tuner Card (DVB-T, DVB-S & Analogue), connected to it is a Skybox and Anlg Roof Aerial. PC also has a Blu-ray and HD-DVD drive and HDMI PC-to-TV output (supports HDCP).
I want to buy good quality products that will guarantee to deliver perfect High Definition sound & vision (version 1.3a) to my TV; and naturally I don't want to pay more than is necessary.
So, if you can assist me by first confirming what I want to do is feasible and second provide advice in finding good quality cables and if necessary repeater.
Have I missed anything out, is there something I haven't taken into consideration, am I completely crazy with what I want do?
12 mtrs is a long way, tbh for the best advice on this I would ask on avforums - AVForums Home
Please let me know how you get on, as i'm looking at setting up a hd projector that will need a similar cable length to reach my skyhd & media center.
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
