How do I modify my recent documents?
nechoha
When you click Start>Documents> (using Windows Classic Start Menu,) it expands to show me my recently opened docs and, in a section above these, it shows my user folder, doc's folder (which can be expanded) and pict's folder. My question is how can I modify this to add other locations / folders to the list?
    AMD Turion64
    Quanta 30 CF
    3 gig
    NVIDIA GeForce 7150M / nForce 630M
Hi Brink,
Thanks for the reply, :) but I already knew about adding to Programs. :(
Being that windows somehow is told to start with to put the three items there, there should be some way of adding to the list, and that is what I am hoping to find out.
Maybe someone else can help?
Nechoha
Hello Nechoha,
I do not believe that you can, but you can add to Programs.
http://www.vistax64.com/tutorials/79571-start-menu-shortcuts.html
    AMD Turion64
    Quanta 30 CF
    3 gig
