You should upgrade or use an
alternative browser .
Solved how do i know if i have 32 bit or 64 bit pc?
I m using 32 bit since last 5-6 yrs but now its time to move to 64 bit. I will download windows 7 build 7100 today. But how do i know if i have a 32 bit or 64 bit pc?
I checked it in system information and it shows x86 based pc but i assume its because i have installed vista 32 bit on it.
Also, if i try to run wubi installer to install ubuntu, it automatically tries to download 64 bit version. Does it mean my pc is 64 bit?
my system: core2duo T5550 @1.83 ghz
2 gb ram, intel g 965 motherboard(its a laptop).
Intel Dual Core 3 GHz
3 GB DDR 2 667 Mhz
ATI X1550 256 MB
Samsung 19"
80 GB IDE Samsung.
iBall
iBall
2mbps
Hello Kavita,
The
Intel Dual Core T550 CPU is a 64-bit CPU, so you can install a Windows 7 64- bit version if you like to. Just make sure that you have 64-bit drivers available for all of your devices though.
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
Biostar
Biostar MCP6P-M2
NVIDIA GeForce 8400GS
CIBOX
Hitachi 160GB
Wow thats good to know. Thank you Shawn n brummyfan.
3 GB DDR 2 667 Mhz
ATI X1550 256 MB
Samsung 19"
80 GB IDE Samsung.
iBall
iBall
2mbps
You're welcome Kavita.
Operating System
Operating System
Lost in Cyberspace
Vista Pro
Even though Windows 7 is not as Resource HOg as Vista is, I would be careful choosing the 64 bit version instead of the 32 since you have a very small processor and 2GBs of Ram only.
Then again, this is just a beta build and you can uninstall and install as many times as you want so... Go ahead.
Intel Q9650 w/CM V8 Cooler...
EVGA GTX260
Realtek High Def Onboard
Acer 22" LCD Widescreen
1680 x 1050
WD Velociraptor 160GB
Samsung Sata 750GB
Maxtor External 160GB
Thermaltake Speedo Advance
Air Cooled... See CPU
Logitech G7
Logitech G15
Comcast 6MB Broadband
Linksys WRT54G router
I also want to know if i can have 4 GB RAM. When i open memory lid, it has 2 slots in which i have installed 1 GB in each slot. Is there a way to find out how much does it support? I really want to say GOODBYE to 32 bit and will soon install 64 bit vista or 7 but want to upgrade RAM so that it works smoothly.
3 GB DDR 2 667 Mhz
ATI X1550 256 MB
Samsung 19"
80 GB IDE Samsung.
iBall
iBall
2mbps
What brand and model is your laptop?
Operating System
Operating System
3 GB DDR 2 667 Mhz
ATI X1550 256 MB
Samsung 19"
80 GB IDE Samsung.
iBall
iBall
2mbps
Your laptop can support up to 4GB of RAM using 2x2GB sticks.
Operating System
Operating System
Thanks for this great help Shawn.
3 GB DDR 2 667 Mhz
ATI X1550 256 MB
Samsung 19"
80 GB IDE Samsung.
iBall
iBall
2mbps
You're welcome.
Operating System
Operating System
