How do I change D/L settings?
blood_fr3ak
How do I change my download options for mp3's?
Instead of downloading them I would like to hear them first. Some how the box got unchecked. How do i re-check it?
It depends where you a d/ling from and what app you are using.
With that info, hopefully somebody will be a able to help you.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
OK, sure.
I'm using Vista with IE 8. I'm trying to d/l backing tracks to play along with on my guitar. For instance like this one. When I click it, it automatically wants to download it. I would like to be able to hear it first before downloading it. I used to be able to do this, but I think my friend unchecked the box that asks if you want to download it automatically. How do I re-check the box that pops up so I can hear it before I decide if I want to download it or not?
