How can I lower the volume more?
omglol741
My headphones are mega loud for some reason. Right now 0 is the best volume setting lol. In XP there was a wave multiplier in the volume mixer that I used to fix that, but I don't see that in Vista. And it was annoying, because I had to change that every time I restarted. Is there a multiplier in some config file somewhere I can change to fix this permanently or something? Thanks
    Intel Core 2 Duo E8400
    GIGABYTE GA-P35-DS3L
    4GB 800 Crucial Ballistix (?)
    NVIDIA 8800GT
    Seagate 7200.11 500GB
Right-Click your task bar
Click Properties
Click "Notification Area" tab
Checkmark "Volume"
Click "OK" button
Your volume control should present itself as an icon next to the system clock
Clicking on it will present you with the master volume control, clicking on mixer will allow you to select the volume for individual applications
If it's still too loud you could go into the control panel and go to SOUND and tweak the settings there.
If all else fails they do sell some headphone with volume control built in and you can control it that way
