HOme to proffession XP
I recently tried fixing a customers computer, i didnt have the right disk so i copied and pasted her files to my HD, and did a fresh XP install, but before that i was trying to fix OS with the disk using restore, the disk i used though required to authenticate the key to login,i saved her files but they are in an unreadable format, because it never set up her old files, after the restore.
any sugestions?
    Custom built Desktop
    AMD Phenom II X6 1090T Black Edition 3.2Ghz
    MSI 890FXA-GD70 AM3 AMD 890FX
    8GB Adata Gaming series 2.0 DDR3 1600
    MSI Twin Frozr 5830 X2 with MSI 5850 Crossfired
    Asus 19", Acer 17"
    1400x900
    OCZ Agility 3 60gb, 500GB F3 Samsung Spin point and 5 other HDD's
    850W OCZ
    NZXT Phantom
    2 200mm fans with 6 120mm fans
    Logitec G9
    Saitek 2
    Major AMD, ATI and MSI Enthusiast.
What are the extensions of the files, for example docx, pdf
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
