Everytime I use windows IE 9 I keep getting a fake Winpatrol pop-up saying would I like to change homepage to MSN, ( I keep it on Google) I always click "NO" but it keeps changing
HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
Realtek HD Audio
Dell E2311H DVI/VGA 5ms response, Full HD
1920x1080 @ 60Hz
320GB Seagate Barracuda 7200.02 SATA II
Cooler Master Extreme Power Plus 700w
Lian-Li PC-6010 With Side Window
Aywun A4 80mm fan
Logitech K120 Wired Mouse
Logitech K120 Wired Keyboard
802.11B/G/N 17Mb/s
AMD Catalyst 12.6
Thomson A/B/G/N Router
LiteON CD/DVD Player
GAME PERFORMANCE:
Battlefield 3: 41 FPS High 1x AA @ 1280x720
Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080
Counter Strike Source (and other Valve games):
300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
Can I please just reiterate richc46's MBAM. There is no point in trying all of these varied fixes until we try the simple, and generate a plan of attack from it. Please run us an MBAM scan:
Malwarebytes' Anti-Malware a.k.a. MBAM - Download Free Version (freeware) - Homepage Why? Malwarebytes' Anti-Malware is very good at removing the zlob trojan, virtumonde, and most other current infections. This single tool has replaced multiple tools that have been required in the past.
Double-click mbam-setup.exe and follow the prompts to install the program.
At the end, confirm a check mark is placed next to the following:
Update Malwarebytes' Anti-Malware
Launch Malwarebytes' Anti-Malware
Then click Finish.
If an update is found, it will download and install the latest version.
Once the program has loaded, select Perform quick scan, then click Scan.
When the scan is complete, click OK, then Show Results to view the results.
Be sure that everything is checked, and click Remove Selected.
When completed, a log will open in Notepad. The rogue application should now be gone.
When completed, a log will open in Notepad. If you need to create a new topic, please paste this log with it.
Note: Some infections will prevent MBAM from running. If MBAM won't run, try renaming the file mbam-setup.exe to a random name, and then try again.
1 x 640Gb (SATA 300)
1 x 1Tb (SATA 600)
Stock PSU - 375W
Dell XPS 420
Stock Fan
Dell Bluetooth
120 kb/s
IE has a link that gives you the option NOT to be asked whether you want to use the new webpage as your new homepage. It's on one of the screens where you select your default homepage. Sorry, but I don't remember exactly where it is --- but it's there, and it should solve this problem!
another option might be, what I did seems to help me was to disable ALL the add-ons that were set under.. IE8- tool- internet options- programs- Manage add ons......
just later on let in the ones i trusted...
