Here's another question about explorer
pacinitaly
HappyGuru Lovin2Help
Hello All,
I do alot of file copy and move between HDD and external and network machine.
Everytime I want to paste a file, I have to drag the name column in explorer left to give room on right then move the last column left also to touch screen and paste.
On XP I can touch anywhere.
anyone else have this issue?
Thanks to Brink, I can save layout and selected views of folder but not the thickness of the columns.
Thank so much in advance,
Carmine
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
Hello All,
Carmine
Hold down Ctrl button and click folders you want to copy over
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    8800GTS 512Mb Overclocked
    5.1 surround sound
    500Gb Samsung SATAII XP 500GB Samsung SATAII
    1000W CoolerMaster power supply
    CoolerMaster Cosmos 1000 case
    120mm ThermalTake Big Typhoon CPU cooler, 3 x 120mm exhaust
    Wireless Keyboard and mouse 3000
    1TB WD My Book Office edition external drive x 2, Dual layer LG DVD-Rom burner, 15 in 1 card reader Triple boot: XP, Vista Ultimate 64 and Windows 7 Ultimate 64
Hello All,
Carmine
that I know, but the paste function is missing unless I move the column "date created" to the left
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
Hello All,
Carmine
Did u adjusted ur dpi setting to non default value?? If it is, that may be cause this problem. from ur screen shot i found that u moved ur task bar to right side. Is this happening while ur taskbar in lower side
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
    100 mbps(office lan)
Hello All,
Carmine
yes, it has been this way since I had vista.
I always have to move the last column left to paste files.
thanks anyway, I've been living with this since 9/2008
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
