help!
mattroland
Hi im a newb as you probably know and the problem im having is that while i was i cmd i must have accidentally changed my password instead of the password of a user i created to practice with which is whimsically name temp.
i would like to know a couple of things (i hope im not breaking any rules :p)
A) is there any command in windows vista 32 bit i can use to bypass the need to open up cmd as admin and allow me to change my admin users password, eg. i am trying the basic, net user [username] *, but it is telling me system error five has occured access is denied. and yes it is prompting me for a password to open it as admin.
B) if there is no such command or its not know openly how can i uninstall my window vista 32 bit from my gateway laptop, i dont need any of the info on it just want my user back!!
Thank you.
Matthias Roland the newb
thank you for posting but i dont have a password reset disk made but if i reinstall windows vista would that work? if so how do i reinstall its so it will be "new" agian?
