help
artoriusking
Cant run Dawn of Magic, 1503AD, or Port Royale x64
please help I cant get Dawn of Magic, 1503AD The New World, or Port Royale 2 to work with solid system running vista x64. any suggestions?
Hello artoriusking,
First off may I suggest you try this
Can You RUN It?
Its just possible that maybe those games won't run on Vista, its worth a try
Hope it helps you
Jekyll and Hyde ;)
    Intel Pentium
    Core 2 Duo @ 2.40 GHz
    Abit AW9D
    4 Gig DDR 2
    GeForce 8800 GTX 768MB
    19" Belinea
    1280 x 1024
    500 Gig Barracuda
    No idea
    Cooler Master
    Logitech G9 Laser Mouse
    Logitech G15
    Broadband at around 750kb's
Secondly, when asking for help (this goes pretty much for anything), may I suggest you explain as much as possible what the problem is and what have you done so far.
Also, posting your system specs can help us help you quicker, otherwise, we are speculating and nobody likes to do that.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
sorry specs vista x64, nvidia 9800m gs, 4gb memory, should be good for any game out just about. Port Royale 2 does nothing after reading cd same with 1503AD, Dawn of Magic will not even read
Have you tried the link I gave you?
Here:
Can You RUN It?
Just search for your games in the drop down list and then click "Can you RUN it"
I only ask as those are old games, at least I think they are
Jekyll and Hyde ;)
    Intel Pentium
    Abit AW9D
    4 Gig DDR 2
    19" Belinea
    1280 x 1024
    500 Gig Barracuda
    No idea
    Cooler Master
    Logitech G15
