Help!
Haven't a clue
My daughter made a wonderful digital camera video called 'I'm soooo bored' and posted it on youtube. To save hard disc space, after we had downloaded it on to youtube, I deleted the file, like a twit, from my hard drive! Now she's gone and deleted her youtube account and I want to restore the deleted movie. Is it too late? How do I find it if it can be restored?
Help! Most appreciated. It must be on here somewhere?
thanks
Dave:(
Well, one option is to check your recycle bin to see if it is still in there. If it is, you can restore it from there. Otherwise, you might want to do a search on google for file retrieval software.....but most of that software isn't free.
Also, have you checked the camera to see if it might still be somewhere on there?
    Intel Core 2 Duo E8400 3.0 Ghz
    Asus P5K Pro
    2 times 2GB Kingston (paired) DDR2 PC 6400
    9600GT 512MB
    Samsung SyncMaster 226 CW
    1680X1050
    74GB 10.000 rpm WD raptor 750 GB Samsung F1 750 GB Samsung F1 2 WD 500 GB drives
    Recom Power Engine 600 Watt
    Apevia X-cruiser Blue
    Auras CTC-868 CPU cooler; 7 Zalman 120mm, 1 Papst casesooler
    Logitech wireless trackball
    50 mbit synchronous fibreglass connection
If the file was deleted a long time ago, I doubt that you will be able to actually retrieve it, but you can always try.
To be honest, I've never tried this, so I can't point you to any programs. Just do a google search on free data retrieval software. Or look on tucows, cnet or any of the other download sites....
    Asus P5K Pro
    9600GT 512MB
    1680X1050
There is always a chance, but you have to understand that a hard disk gets written to all the time, and the operating system usually uses any available space.... and as this was a deleted file, the OS sees it as available space.... the more time has passed, the less chance there is of it still being retrievable
    Asus P5K Pro
    9600GT 512MB
    1680X1050
Hello Haven't a clue, and welcome to Vista Forums.
If you had Vista Ultimate, I would recommend using Previous Versions to see if you could restore it. Since you do not, the free program Recuva may be able to help if it has not been to long.
I hope that you will be able to recover the file.
    Intel Core i7 920 @2.67GHz
    EVGA X58 132-BL-E758
    6 Gbs Corsair 3XM
    2 Nvidia GeForce GTX 260 Core216 Superclocked
    Vizio 22 LCD
    1920x1080
    Western Digital 640 Gb Western Digital 1.5 TB
    Corsair HX1000
    Coller Master HAF 932
    Xigmatek Dark Knight
    Logitech G%
    16MB Down 1.5 Up
