Solved Help
bmart727
Internet Explorer 7 and FireFox are not working. COD4 has lost the internet connection. AIM still works as well as the other ie browser. I have Vista x64 Ultimate, I made recovery cds on my friend's HP computer whom own's Home Premium. Is it ok to use this if so I will. But if there is anyone who knows how to fix it, please help.
Hi mate, first of all calm down.
Fill out your system specs so we know what we are dealing with.
What other IE browser are you using? Have you updated?
It is possible the update could have caused the problem, try to restore before this problem started to happen.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Ok so first of all I was lazy thinking that I didn't need to create a restore point yet. Now I have to pay for that because gateway never gave me a vista disc. I have a gateway P-173 FX, a 2.20 ghz duo core processor 4 gigs of ram 8800m gts graphics and a 64 bit operating system. Yes during the time I have used it there has been a few updates. I was home for vacation and it worked fine until I accidentally shut it down wrong and since then it hasn't worked. The other ie browers I am using is the one in my task bar. There are 2 of them, one says internet explorer(64-bit) and the other is just internet explorer. The non 64 bit one is the one that works, it has full access to everything but my college email, but I can access my hotmail email. Like I said I have my 3 disk made here to restore to home premium but its a last resort, everything is failing and I have college work to due >< plz help :D.
Hi bmart727,
There may still be restore point available yet you have not created them yourself. They may have been made automatically when installing updates, unless the function is disabled. Have you checked? You can refer to this tutorial: How to Do a System Restore in Vista
    Dell XPS720
    Intel Quad Q6600 2.40GHz
    4GB DDR2 800MHz
    Creative SB X-Fi Xtreme Gamer
    Dell 2407WFP-HC
    1920x1200
Yah, I already tried to system restore twice to the earliest date that it could possibly restore to, It was november 27th, so I tried to restore and it still doesn't work. I think it is something wrong with my registry or maybe some sort of virus. I think maybe I should just reformat.
If the restore point is older than the problem, you may want to revert back. Doing a virus scan will not hurt, if you have no AV program installed, there are free scanners on the internet, eg on Kaspersky's homepage. You can also look for errors in the Event log (start - search for event viewer) and the Reliability Monitor (search for reliability and performance monitor). Post back. Someone here may have a solution if provided some more clues. You could always test to run IE without add-ons (Start - All Programs - Accessories - System Tools) to see if this works, though perhaps against the odds. Good luck!
    Dell XPS720
    4GB DDR2 800MHz
    Dell 2407WFP-HC
    1920x1200
Ok so I checked both the event viewer and the reliability and performance monitor. The computer seems to be running fine. However in the event viewer there are many errors, this could be the main source of my problems.
Hi bmart727, are the restorations you tried twice complete successfully and then the problem persists or it did complete the system restore? Have you try to system restore it to original factory condition? What do you mean by "accidentally shut it down wrong"? If it didn't work, has the laptop been dropped that may causing internal damage?
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
I want to restore it to the original factory condition, but i dont know how. And by shut it down wrong, I mean I hit the power button, and then it was like windows has been shutdown in a improper way or something like that. No I have never dropped it, its my baby I payed 1600 or so for it, I treat it very well. Also the restores that I tried, were on the date of november 27th and they completed successfully and the problem still persist, The problem had occured before that date anyway.
Hello bmart727.
You should be able to find the info to restore to factory either in the manual or at the manufacturers web site. As for IE you might try a reset. Info here if needed. http://www.vistax64.com/tutorials/114310-internet-explorer-reset.html
Not sure that will work since FF is also having a problem, but maybe worth a try.
Please keep us posted.
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    MX Revolution
    Microsoft Comfort Curve
Also when I try to start programs like microsoft word I get these errors. C:\Program Files (x86)\Microsoft Office\Office12\WINWORD.exe
The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log for more detail.
Yo thanks for taking time to look at my post, Eventually I found a gateway recovery tool that would allow me to reset everything back to factory settings. So I backed up all my info on a external. Good news after the reset everything works fine again and I have a brand new pc.
Great! bmart727, Congrats!
Have nice holiday!
    E6850
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Glad you got it sorted. If you have anymore problems/questions, you know where to find us.
Take care & Have Fun!
Gary
    Creative SB X-Fi
    HP w2207 + HPvs15
    MX Revolution
Hi, bmart727,
Now you are back working ...
as you have Ultimate and if you have sufficient space on your external drive, you may want to think about making an Image backup of the working system, I would suggest that if you install your main applications and then make the backup it may make things easier if something similar happens again Hopefully nothing will happen in the future but I find the fact of having the backup gives a bit of reassurance :geek::D
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Samsung 32" TV
    68 MB Down 18.5 MB Up
Call your support let them take over your PC. I've done this many times. They are there to help.
SIR VORTEX USA
    HP Pavilion Elite m9350f
    AMD Phenom 9850 Quad-Core Processor 2.5GHz
    6GB PC2-6400 DDR2 SDRAM expandable to 8GB
    GeForce 9800 GT second generation, 512MB discrete memory
    Realtec High Definition
    22 in Acer AL2223W
    1600X1200 +
    750GB 7200RPM SATA
    500 watts ?
    Standard from HP
    3 Fans standard with HP unit
    Logitech Laser MX3000
    Z-Board for gaming and the Logitech MX3000 for the net.
    8 kbps
    Have own server on CODWW called SIR FALCON USA , enjoy Delta Force Extreme @ 6:00 p.m. EST on Falcon Bandit Sniper and Falcon Wars on the weekends (sat.+sun.) Have the Saitek X-52 controls for MicroSoft Flight Simulator. Check my fishing forum if interested: wwwgreatlakesforum.com I go by h2o on it. USA stands for United Snipers Association fyi
