scissormetimbers
ok so i just installed a new motherboard into my computer, and for a while it was working fine and dandy but then suddenly it would not turn back on after i turned it off to check something. what was happening was it would give a short burst of life and then immediately shut off. i thought it wasnt getting enough power so i set my power supply dial to 'hi' rather than 'auto'. big mistake. now whenever it tries to power on it sort of revs up and lights up then it goes off and on until i finally flip the power switch to off. i dont get anything on the screen so i dont know what the problem is.
- AMD Athlon 64 3700+ 2.20 GHz
- Biostar GeForce 6100-M9
- 2046 MB
- nVidia GeForce 7600 GT
- 120 GB Seagate
