Help with wireless connectivity issues
Katokato
Banned
I have a wireless router (linksys), but when i try to connect to it with my desktop (has an attached reciever on it) the connection keeps dropping, and coming back up again. How do i fix this so my wireless connectivity will stay solid (or not drop as much), but with ethernet (hard wired) the connection stays steady so i think its not a router problem. plz help thanx
-thanx
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
Try re-setting your router.
  1. Unplug the power cord to the router.
  2. Wait approximately 30 seconds.
  3. Plug the power cord back in.
    HP Pavilion Elite
    Some Amount of Motherness
    6.O GB RAM
    Some Amount of Soundness
    1440x900 & 1440x900
    WD Caviar Blue 500GB
    Some Amount of Voltageness
    Hp Pavilion Elite Case
    Some Amount of Coolingness
    HP: M/N:M-SBQ133
    HP: Model Number: KB0911
    Comcast: 20 MB/S
no, the router itself is fine, i can get a steady connection when im directly connected via ethernet. but when i use wireless, the connection between router and wireless router keeps dropping. and i also use my laptop (even farther from the garage) and i still get stable signals, the problem is is that with my other pc (has a wireless adapter) the connection keeps droppping, and it is closer to my router than the laptop is!
plz read questions first instead of putting random answers (sorry if im being rude)
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    normal black case
    fans
    dsl
    2.3 ghz amd
