Hi Guys,
I purchased the Easy Transfer Cable (Vista compatible) and installed the included software on my old computer (windows XP, laptop about 5 years old). I connected the two computers as instructed, and chose the custom setting because I only want some files and settings to be transferred, but when I start transferring I always get a message during the first stage, when the software on my old computer says it's trying to "gather information about the system;" I get an error message (on my NEW laptop, with Vista Home Premium) saying, "there's an error with the connection, and the easy transfer program will close down now." In this case the old computer seems to be doing ok though. I tried about 3 times and I get the same message everytime!!
I searched the forum but none had the same kind of problem I mentioned (people mentioned scanning problem, connection problem, or mostly happen with the old computer hanging), but not on the NEW computer with the same error message. I'm really frustrated because it's taking up a lot of my time already, and I can assure you the connections were fine all the time (they're sitting next to each other, with cable firmly attached). Anyone could help me please?? Or is there a way I could just use the cable and drag the files I want to the new destination?
Thanks all,
mirr
Thanks all,
mirr
