HELP with USB Printer
idahjo
Bush did it....
I did a clean install with VISTA ULTIMATE (same program as-was). I have been trying to figure out all day why the USB laser jet printer will not print. It is supposed to 'see and install a USB printer when switched on', but it won't. Nothing was changed on the hardware hook-up since it worked fine on the previous VISTA O/S.
I know this is got to be a simple fix, but danged if I can figure it out?:confused:
    self-constructed
    3.10 gigahertz AMD Athlon 64 X2 Dual Core
    Gigabyte GA-MA78G-DS3H
    4Gb Corsair
    HIS 8450
    AMD 780G onboard
    DELL 2405FPW
    2) WDC WD6400AAKS-00A7B2 640Gb
    a 'couple clicks faster than smoke signals
Try add printer and see what you can do.
Install drivers as well.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
Make sure USB cable lenght is less than 5 meters, otherwise your computer may not "see" the printer
    hp dv6314tx
    4 gb
~Lordbob
It tells you when you ADD A PRINTER, not to do it if it is USB as it will find itself. I have tried both ways, and it won't work either way.
Notice; I said that it worked GREAT hooked up exactly the same with the original (same) VISTA O/S. :( Only thing different was clean install of (same) O/S.
    self-constructed
    4Gb Corsair
    HIS 8450
    AMD 780G onboard
    DELL 2405FPW
Well then its Vista thats the problem... Drivers?
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
