Help with usb harddrive from HP!
dangerousdave
Hi guys! nice forum!
I got a new computer with ultimate 64x on and plugging in my external hardrive, a HP HD3000 via usb and vista first said "want to download drivers?" I did that, but got the message "the best driver is allready installed". Ok, well onward.. but no, it dosent even come up in systemlist.. Started adminpage with the dischandling in it (dont really know the name for it since I use swedish Vista). there I can see the harddrive but it´s not given a driveletter, I can check its properties and atempt to update driver but nothing works. Cant even format.
It works fine on my old xp machine and I have some mp3 on it. I formated it earlier with ntsf.
Checked Hp.com for help but no drivers there to be found. Tried contacting the hp suppport but i wouldnt accept the serialnumber of my drive saying it was wrong.. uh.
Other usb devices work just fine, mouse and keyboard.
So any ideas? been googling around and havent found a solution.
Thanks In advance
Regards
Dave
Sweden
    Q6600
    Gigabyte x48 Dq6
    8 gig ram OCZ DDR2 PC8500 4096MB x 2
    XFX 9800X2 1024 ram
    Creative Xfi extreme audio PCI-e
    23 inc HP wide
    1920x1200
    2x 500gig samsung 1x 36 gig Raptor 1x 500 USB
    Coolermaster 620 modular
    Antec Nine Hundred
    Zalman 9700LED
    Razer deathadder
    Microsoft 4000 ergonomic
    37mbit/6mbit
    Built my own computers for sometime. This is my first computer with a 64 bit OS.
Bumping this, No one knows?
Dave
    Q6600
    Gigabyte x48 Dq6
    XFX 9800X2 1024 ram
    23 inc HP wide
    1920x1200
    Antec Nine Hundred
    Zalman 9700LED
    Razer deathadder
    37mbit/6mbit
Hi Dave
Vista should have the natve drivers this external drive needs to be recognized, so it shouldn't need an updated driver.
It seems that for some reason, Vista just "burped" when trying to initialize this external drive and it's not fully operable. Have you tried unhooking the drive, then reboot without it, then shut down, hook up the drive and reboot again?
Or try hot-plugging (unplug & plug in while booted) it and see if Vista can recognize and install it properly again?
There is also an option in the Disk Mgmt applet to "Rescan Disks", open Computer Mgmt - Disk Mgmt, click Action - Rescan Disks, you can try that too.
I had an internal drive that was doing just about the same thing you're experiencing and it worked itself out after I played around with unhooking it, rebooting, powering off and hooking it up again, then rebooting. That usually fixes any problems when the system has trouble with recognizing and installing hardware properly, as long as it's not a case of failing hardware.
    Personal Build
    Intel E6750 Core 2 Duo
    Asus Commando MoBo (P965/ICH8R)
    4G's Crucial Ballistix Tracer DDR2 PC26400 RAM
    BFG 8800GTS OC2 320MB
    Creative Sound Blaster X-FI Platinum FATAL1TY (next)
    2 x 22" w2207 LCD Monitors
    1- 1680 x 1050, 1 - 1920 x 1080
    3 x 500G SATA II WD Caviar HDD's
    EnerMax NoiseTaker II 600W
    NZXT Lexa Classic (modified, dual doored & windowed)
    Zalman 9700 CPU cooler, 4-120mm fans, 1-90mm
    Logitech Optical Trackman trackball
    NZXT Lexa Classic Case, Zalman 9700 CPU Cooler, 2 DVD Burners c/w LightScribe (Sony, TSST), Enermax NoiseTaker II 600W PSU with Custom Chrome cable sleeving, Hauppauge HDTV TV Tuner Card, 5.1 Logitech Z5500 speakers, 15 in 1 Multi-card reader
Hi and thanks for the reply! The hardware works! just used it on this laptop of mine that Im using at work. Will try what you just suggested. Thanks for replying!!
Dave
    Q6600
    Gigabyte x48 Dq6
    XFX 9800X2 1024 ram
    23 inc HP wide
    1920x1200
    Antec Nine Hundred
    Zalman 9700LED
    Razer deathadder
    37mbit/6mbit
