0rr6yui192
hello,
I have one hard drive partitioned in two, both have windows vista installed. The two partitions are windows vista home (not working right) and windows vista ultimate (working). My problem is that the vista home partition is set as the active primary partition when i want the vista ultimate partition to be the primary as opposed to a logical partition. i went to change the logical partition to primary and make it active but when i did this it made my computer nonbootable so i changed it back. I can boot into both partitions with no problem and i have managed to set the vista ultimate drive and a primary drive as well but not the active drive. so after all this, i need help making the vista ultimate drive bootable and delete the vista home partition. personally i think the problem is that since windows installed itself on a logical drive it never wrote and mbr to that partition and therefore makes it nonbootable when set as active. so again if someone can help me do 2 things: one- make the vista ultimate the primary active partition. and two- delete the vista home partition. if anyone is unclear about all this then ask me to explain because i know i am not the greatest at wording things.
thanks,
thanks,
- Operating System
- Vistax64
