Help with Office 2007
zungul
Hi
Everytime when I try to open Microsoft Office 2007 I'm getting message: this file could not be found, (C:\Windows\system32\Files.doc. After this I press OK button and I'm getting second one: The directory name is not valid. (C:\Windows\system32\(x86)\Microsoft.doc) I press Ok and program open and works fine.
I know that I can use office but this thing really bother me because I know that something is wrong and maybe after some time it will be bigger problem.
Can someone help to find out what's wrong. :huh:
Load cd/dvd into computer, wait for prompt. You should see a screen with 3 options uninstall, add and repair. click repair. If that doesn't work completely uninstall it and then reinstall.
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
