I know this is a Vista forum but you folks are so well informed and nice that I want to take a little advantage of that if I may.
I recently purchased a refurbished IBM T42 lappy for the office, part of the reason why is because it comes with an integrated parallel port that I need for the software we use to sell our products.
Anyways, there was no CD with it as it appears an image made from Acronis comes with the lappy in case you need to do a clean reinstall of the XP OS.
Here's where I need help...:
The software we use runs on Windows 2000 Server so I would need to create a partition for me to be able to install the software but I would hate to destroy the XP OS already in it... is there an easy solution to this?
I know I did something similar when I did my dual XP + Vista boot but I doubt it will work with this since I had to use the Vista CD to make this happen.
Any takers? and if so... can you kinda take me by the hand with the blow by blow of how to do it?
Thanks folks.
Thanks folks.
- Custom Built
- Intel Q9650 w/CM V8 Cooler...
- EVGA 780i SLI FTW... Latest Bios & Drivers
- Corsair Dominator 8GB (4 x 2GB) PC2-8500C5D
- EVGA GTX260
- Realtek High Def Onboard
- Acer 22" LCD Widescreen
- 1680 x 1050
- WD Velociraptor 160GB Samsung Sata 750GB Maxtor External 160GB
- PSU
- PC Power & Cooling 750w Silencer
- Case
- Thermaltake Speedo Advance
- Cooling
- Air Cooled... See CPU
- Logitech G7
- Logitech G15
- Comcast 6MB Broadband
- Other Info
- Linksys WRT54G router
