help with itunes
spanna
Hello
I am having trouble installing iTunes on windows vista 32bit. It downloads ok but when i try to run it error msg is ' itunes setup is not a valid win 32 application'
i have checked and version 8 iTunes should be compatible with vista.
I can't even install quicktime.
Can anyone help?
I have exactly the same problem - have downloaded iTunes 7.2 as this is meant to be more compatible with Vista than 8, but when I try to install it (open/run) I get the same error message.
Same goes for Quicktime.
The most frustrating thing is that I did have itunes installed and working no problem for the last year & a half, but uninstalled Quicktime in an attempt to get better performance, without realising that its needed for itunes. Please help!
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Coolermaster Silent Pro 700M
    Antec 900
    Tuniq Tower 120 LFB
    Logitech MX400
    Logitech EX110
    Graphics Driver - 190.38
Hello
Can anyone help?
Cause: you get this error when your browser is not downloading the entire file and is just downloading a part of the file.
Go to itunes.exe properties and check the downloaded file size.
Resolution: Try a different browser.
create a new user account and try downloading and installing itunes...;)
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
    Compaq
    15"
    160 GB WDC
D'oh!
Unfortunately neither of the 2 suggestions have worked...I tried everything and at all different hours of the day and night to download itunes in2 different browers, but to no avail....the download would start (SLOWLY) and then never complete. I was convinced that my laptop must have a virus, so I bought the top of the range McAfee virus software, installed it, expecting to find a million virus alerts - NOT ONE.
So now I have no idea why my windows vista laptop that was running itunes a couple of months ago no prob, wont download it?!? I need music :(
If anyone has any ideas I'll be forever indebted...
Have you tried to download it on another computer (with another internet connection) and just put it on a USB?
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Antec 900
    Tuniq Tower 120 LFB
    Logitech MX400
    Logitech EX110
Yup, that's my back-up plan, mattinahat. Unfortunately everyone I know has macs and at work (where we have PCs) we have to be administrators to download programs. There must be someone in this city that can throw me a copy!
Will 'put it out there' and keep you posted.
Cheers
What about an Internet Cafe?
You can usually download programs there.
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Antec 900
    Tuniq Tower 120 LFB
    Logitech MX400
    Logitech EX110
Hello
I am having trouble installing iTunes on windows vista 32bit. When i try to run it error msg is ' itunes cannot find xxx directoty and need quicktime to install.'
I can't even install quicktime and thats a sepparate installation.
Please help :cry:
