Pwn3d4lif3
Alrighty, from looking around here. Seems like a ton of smart computer people here. Maybe you can help me :D
Lets start with my Stats on my computer.
System Model: Dell DXP061
System Type: X86-based PC
Processor: Intel(R) Core(TM)2 Quad CPU @ 2.40GHz 2394Mhz 4 Core(s)
Graphic Card: ATI Radeon HD 3800 Series
4 GB of RAM
Alright with many games that I'm playing with. There are a few things that are going on that I'm not liking.
Yes I know I play Gunz The Duel, and it seems like there is screen lag or something, maybe a delay, not sure what to call it. People were telling me about all the Services that Vista uses slows it down or such like that. Is that true? Or is there another way to fix it.
I also play Crysis, and problem with that game, is that it isn't using all of my RAM or memory? It only uses so much, and just leaves the rest alone. Anyway way to make it use more? Also the game supports Dual processors. I have Quad, is there a way to make it use all four of them?
Also just with any games, is there a way to just make the games run faster at all without killing the graphic, cause I know my PC can handle the graphics, it just seems like my PC isnt using everything that I put into it.
Thanks for your help :D
4 GB of RAM
SK
Detail vs performance is all trial and error.
