MelindaSue
ok these past couple days have been very frustrating for me< i have been trying everything anotheing wants to work right now on my keyboard no numbers are working< nor my caps< when i press my caps my letters go lowercase when i unpress my caps they go large when its suppose to be opposite plus my commas period ect dont work either for a bit i was using number lock after word to rtry the del key so i can get a period after using my sentences but after that is no longer working
then someone told me to go into my device manager to uninstall my keyboard now when i click that folder all the folders select at the same time highlighting and they all open at the same time which i know is not normal plus i lost all my icons on my desktop and when i did have my icons on my desktop and drag them where i want them they would go there< but when i drag them they copy and copy making millions of duplicates i would delete them and then i dont where they would delete cause i had so many trash can i dont even which on was the original so i dont know if that one was deleted and when i try searching for it on the computer well the same one was there but nothing in it so i dont know whats going on i know my computer is going nuts lol
but for the period and commas i get this with shift or without shift so its the same thing anyway im getting frustrated thats for sure<> thats the symbols i get when i try clicking my numbers i get !@#$% and i cant type in no numbers
anyone can ya please help
thanks so much
hugs melinda
thanks so much
hugs melinda
