Help with explorer.exe
howieday22
Every time I try to shut down my computer I get an error message saying something like the application 0x______(different every time) referenced memory at 0x0000000 that could not be read. I have done disk clean up, it did not fix it. What would cause this and what can I do??
    Dell Inspiron 530
    250 gb
    nvidia GeForce FX5200
Sure. Thanks for taking the time to help.
error is as follows:
"the instruction at 0x76b284fd referenced memory at 0x00000000. The memory could not be read."
    Dell Inspiron 530
    250 gb
Can you do the following,
open command prompt as administrator (Right Click and RunAs Administrator)
then type sfc /scannow
(It Would take around 20 mins to finish)
Onces thats done Restart the computer. Check if you you still have the problem.
If this doesnt work do the following
goto to control panel , Administrative tools , event viewer , look under system for errors that matches the time when you shutdown the computer and you get the error msg , you will know the application that is causing this problem
try re-installing or repairing the application, or just post the event error over here
Hope this Helps
Cheers !!
Well, I tried to shut down before doing the things you recommended and it did not happen. I went to the event viewer and it appeared that it was a dhcp client error... Do those randomly fix themselves without any actions by user?
    Dell Inspiron 530
    250 gb
