Help with Driver
Rom
Hi Guys
Just new to all of this hope someone can help please
well i have just got a new Gecube Radean HD 2006pro AGP
i am running windows vista 64bit OS could anyone help and tell e where i could get the drivers. i have the drivers but not compatable with 64bit
thanks Rom
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Thanks Johngalt
i downloaded the the driver from ATI Site but still with no luck.
i get a THE INF FILE WAS NOT FOUND. so i guess thats why it will not install any help on this.
Regards Rom
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I just went to GeCube's site, clicked on the software link, then found the Radeon HD2600XT GDDR3 256MB AGP 8X Dual...etc card, then picked Vista, then picked driver and downloaded it - it is 128 MB - and in that zip folder is a Bin64 folder - so it *does* have the 64bit driver.
If you click on the HD2600XT, DDR3 512MB card, you get he 8exact* same driver ZIP.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Thanks Johngalt
for your help but still no luck , but i did get to install it on XP XP64 AND VISTA 32 so i will just stay with vista 32 for now.
regards Rom
If you get the .ZIP version of the file, and extract it, it has the bin64 directory - which has the drivers and the setup file - run ***that* setup.exe file in the Bin64 directory and you *should* get it installed on Vista X64 - but, as I noted before, it is the same exact file for both XP and Vista, so you may be right, the drivers may not actually install in Vista x64.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
