Help with CPUz (may be nothing)
KW73
Hello, very new here and not sure if anyone can help. This doesn't have to do with overclocking, but the people here seemed to know a lot about this, and I could not find a better place to ask. I have very low FPS using a NVidia 8800 GTX, which has prompted me to try and figure out why. I am guessing CPU or Ram issues. While testing some thing, I came across CPUz. I installed and ran it, and when I validated I got this:
My question is; why is FREQ in red? Is my CPU not clocked correctly? Any advice would be greatly appreciated.
It's in Red just to highlight it. Your chip is running at the clockspeed it should be :)
As for the poor performance, have you updated your drivers etc?
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Thank you. Was worried it wasn't working correctly.
In answer to your question, I am all updated on drivers. After much combing through google and other places, I have come to realize that my CPU is just too slow to keep up with my expectations of my GPU. I am going to upgrade my CPU tomorrow and see if that fixes the issue. If not, then I will get a new video card and hope for the best.
Thanks again.
No worries mate. Yes, you would be a bit CPU limited for games.
Good luck :)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
You dont want that core anymore! Holla;]
    Me
    i7 920
    Asus P6T
    12 gigs corsair (TR3X6G1333C9 x 2)
    Dual 285 GTX's
    Sennihesir 350 headset.
    Dual 24" dell
    1920x1200
    WD VelociRaptor 300GB Seagate baracuda 7200.12 1TB
    Thermaltake 1200W ToughPower
    Antec P193
    Air(ATM)
    G9
    Orginal G15
    Cable
Hi im sure its not the cpu. click on the graphics tab as it might be the graphcs card,
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6 Thomson A/B/G/N Router LiteON CD/DVD Player GAME PERFORMANCE: Battlefield 3: 41 FPS High 1x AA @ 1280x720 Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080 Counter Strike Source (and other Valve games): 300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
What is the gpu temp? If your card heats up, it'll lag.
Depending on the card, it could start around 100C. I like using hwmonitor to get all my temps and volts.
Its from cpuid.com
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
