Help with blue Screen Dump file
roeelo
Hello all.
I shut down my Vista Ultimate last night and today when i opened the PC i got Blue Screen, and it said that a Dump file was saved.
I found and zipped the dump file, and i will be glad to upload it here if someone can tell me what to do to prevent it from happen again...
Thank's for the help!
Hello all.
If you upload the minidump(s), from the \windows\minidump folder, someone may be able to help you understand the crashes. Until then, it's not possible to help in any non-guesswork way.
That's analysis - that's not the dump file. If you're going to attach that kind of output, you need to ensure your symbols are right first. Otherwise, attach the minidump itself.
Here's the error in the minidump:
The registry cannot load the hive (file):
\SystemRoot\System32\Config\SOFTWARE
or its log or alternate.
It is corrupt, absent, or not writable.
Run CheckDisk to ensure that you don't have hard disk problem
(s).
    AMD Athlon 64 X2 6400+
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    1280x1024@32bit@75MHz
    1 x Seagate 120GB SATA (OS installation) 1 x Seagate 200GB SATA 2 x Seagate 320GB SATA (Hardware RAID 0) 1 x Seagate 250GB IDE (in external USB box) 1 x TrekStor 750GB USB
    650W
    Logitech Cordless Optical
    Logitech Cordless Desktop EX 100
    8192 kbps / 640 kbps
What does the path "\SystemRoot\System32\Config\SOFTWARE" mean?
It means the OS is having trouble accessing a very important portion of the registry from its disk-based file image, hence the recommendation to CHKDSK.
[It also means Mr.CyberZeus is probably using private symbols :)]
I'm not using private symbols. It was written that way in the minidump :)
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    650W
I tried to run Check Disk, but it gave me an error message.
I printed the screen, and attached the message.
what can i do now??
Navigate to Start>All Programs>Accessories. Then right click on Command Prompt, and choose Run as administrator. Then try to run the check disk command.
Hope this helped
    Compaq Presario C700
    Intel Core 2 Duo 1.67 GHz
    Intel GM965
    2.5 GB (2 GB Transcend + 512MB Hyundai)
    Intel Intergrated 965 Express Graphics
    Conexant High Definition
    Compaq
    160 GB Compaq
    Alps Pointing Device Touchpad
    Compaq
    2 Mbps Download, 512 Kbps Upload
    Integrated Web-Camera (P.S. Have another custom-built PC with Win7 x64)
Start --> All programs --> Accessories --> right click on Command prompt --> Run as administrator.
So you can run chkdsk.
I suggest you tu enter the following command:
chkdsk C: /f
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    650W
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    650W
Most likely you'll have to run the command prompt with elevated privileges.
To do this, go to Start and type in "cmd" (without the quotes)
At the top of the search box will be an entry for cmd.exe - right click on that and select "Run as adminstrator". Then try running CHKDSK /R
What next... hope the error will not pop up again...
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    650W
This tells us that the registry is corrupted, and that chkdsk /r won't fix it.
So, it's probably a corruption of your registry. To fix it you'll have to use System Restore to go back to a point before the error started to occur. If you don't have a System Restore point to use, then you're looking at reinstalling Windows.
FWIW - I've seen similar issues with malware infections. Have you been checked out in the malware forums for an infection?
No maleware or viruses. and since my reported blue screen i didn't had another one, but I'm being cautious so I'm interesting in prevention.
By the way, i didn't do the chkdsk /r or chkdsk C: /f that was suggested, only chkdsk, and it told me that i had no bad sectors. should i do chkdsk /r? (what does it mean anyway?).
